Delicate Flower
It is tight but there is some room! Great thought!Hopefully there is a little head room between the compressor and the seat…after running it for ten minutes, it can get seriously hot…
Thank you. I really enjoy the system, thus far. At least I don't have to worry about the AUX battery conking out again randomly. The G screen monitors the battery so I can see the status from inside the cab (once I get it installed). I went with the ones they recommended and they seem to be solid batteries.This is too complicated for me to understand but it seems quite sophisticated and impressive!
Hopefully the batteries are okay. I heard that the batteries delivered with some Genisis kits are junk, fail right away, and are difficult to get replaced under warranty.
You might want to air down to trail pressure, then air back up and check if you might want to add some heat shielding…It is tight but there is some room! Great thought!
Thanks for the advice. I didn't go down to trail pressure (20psi) but I'll definitely run that. Fortunately I have some laying around so may do that just for due diligence. Thanks for the helpful post!You might want to air down to trail pressure, then air back up and check if you might want to add some heat shielding…
I just had a buddy light his back seat on fire, possibly rechargeable battles for cordless tools…seats are definitely combustible…
That is not the battery brand that had the problems.Thank you. I really enjoy the system, thus far. At least I don't have to worry about the AUX battery conking out again randomly. The G screen monitors the battery so I can see the status from inside the cab (once I get it installed). I went with the ones they recommended and they seem to be solid batteries.
Batteries in my Kit
Thanks great to know. Thanks for the input!That is not the battery brand that had the problems.
Probably no trail fix for that huh?Will be interesting to see what you think of those Apex valves. They certainly make airing down fast but they have a tendency to snap off and THAT deflates a tire in a hurry.
Maybe its just the profile on the Hutchisons but I've managed to snap two off in six months...
Nothing quick. They are held in with locking nuts on the back side so you can't get out the broken piece without breaking down the rim. So not a trail fix but certainly doable (and done) over a couple beers at camp that night..... assuming you are carrying spares. Hutchisons are pretty easy to break down. Will likely go back to rubber stems when I have to replace the tires.Probably no trail fix for that huh?
Yes sir can't wait! Good talking to you as always Jeremy.Looking good!! Lot of work but always worth it in the end. Was great chatting with you today Erik! Hopefully we can get those dam RCV’s shipped soon
Wow that is crazy and sorry to hear that! Fortunately I haven't had that happen, hopefully never, but work has been so busy I haven't been wheeling much. I'll definitely pay attention to that. Has APEX take care of you?Will be interesting to see what you think of those Apex valves. They certainly make airing down fast but they have a tendency to snap off and THAT deflates a tire in a hurry.
Naw.. I didn't complain. I'm the one dragging the wheels over rocks and they really aren't that expensive.Wow that is crazy and sorry to hear that! Fortunately I haven't had that happen, hopefully never, but work has been so busy I haven't been wheeling much. I'll definitely pay attention to that. Has APEX take care of you?
Thank you again for the tip. I got some ceramic fire blanket that sits between the compressor and seat.You might want to air down to trail pressure, then air back up and check if you might want to add some heat shielding…
Awesome glad you got it all installed!Just had this stuff installed:
Evo Front Truss Kit
RCV Front Axle Shafts
Synergy HD Ball Joints
Reid HD Knuckles
Teraflex Delta Brake Kit
Artec Rear Axle Truss
Adams 1350 Front/Rear Drive Shafts
Revolution Rear Axle Shafts
ARB Pressure Control System
Thanks bud. I’ve been meaning to leave you some positive reviews. Anywhere in particular? Thank you for all the help, advice, and always being reachable.Awesome glad you got it all installed!
