Moving along nicely! What color powder coat are you going with?
You made quick work of that. Great job!
Did your cage come with spacers? If so, use them to help push the uprights in and the door won't rub.
I too had to trim the shit out of my dash sides, but doing so allowed for a nice clean and flush looking install. A super sharp straight razor is your friend.
Yes, I plan to use the shims on both sides. The passenger side doesn't fit as well as the driver side. Trimming the dash is a must to get the uprights to fit correctly. The door just barely hits on the passenger side upright but, I moved the door hinges out slightly to provide just enough clearance.
I used my jig saw to trim the dash...came out pretty good.
Thanks! Decided to go with satin black.
Awesome job on the installs! We had to install spacers to help give a bit more breathing room at the doors as well so you're on the right track. Can't wait to see it all finished. [emoji106]
I'd recommend flat black on the dash bar. :yup:
Oh and I see some dirt behind your dash. :grayno:
Why flat black? Is there an issue with glare. Maybe I'll have the entire cage powder coated flat black?
I am very light sensitive. The last thing I need is glare off the roll cage. I had mine done in flat black (color matched white gloss on the other parts) and have no issues. I've talked to multiple people who have gloss paint on the dash bar (mostly colors, not sure if any black) and regret it. Just my :twocents:
Thanks! I'll definitely be installing the spacers. Don't want door scratches!
Good eye!! I thought I blew out all the dirt! Lol
Also, if you are inclined to get fancy with your A-pillar plastic trim to make it look nice, I found that a barrel sanding bit on a dremel worked great. Just go slow because it will burn through the plastic trim quickly.
