Disciple Off Road
Looks great sir!
One inch is all you need sometimes. (Que Overlander with snappy reply)
That's what she saidLooks great, got big quick!
Clean engine though for an 8 year old vehicle. Maintenance looks on point.You would think changing the spark plugs on a 2015 JK would be easy...until you discover oil leaking around the drivers side spark plug tube seals and rear cam sensor.
That sucks!You would think changing the spark plugs on a 2015 JK would be easy...until you discover oil leaking around the drivers side spark plug tube seals and rear cam sensor.
Oh, thought this was just you detailing the motor…You would think changing the spark plugs on a 2015 JK would be easy...until you discover oil leaking around the drivers side spark plug tube seals and rear cam sensor.
He is detailing the motor…Oh, thought this was just you detailing the motor…
That looks great! Nice job!Revised my DIY fridge mount. More secure and cleaner now.
Awesome! I really need to do something like this for our 392Revised my DIY fridge mount. More secure and cleaner now.
Like itRevised my DIY fridge mount. More secure and cleaner now.
I'll post up more pics soon.. I had the same issue as you; it was a PITA to prep and took too long to setup. The angle bracket is held in place with the rear seat bracket bolts. To support the front of the platform, I ran a small ratchet strap from the rear cargo hook to the front seat frame bracket. It takes about 5 minutes to install. I may do more refinement in the future but for now, I'm pretty happy with it...Like it
how are you keeping the platform from moving around on top of the seat back or is attaching it to the angle bracket enough?
my setup is a PIA to prep for trips and I can't get my ocd brain to uncomplicate it lol
Excellent! much easier than what I've been doingMade from scraps I had lying around in the garage...It's not pretty but it serves its purpose.
If you go this route, you will need a longer bolt: 12Mx1.75 45MM long
If you go this route, you will need a new nut: 12Mx1.75
