Ddays
EVO/Rotopax mount solution
So I found a solution to the EVO tire carrier issue a couple weeks ago. Was surfing online and stumbled across these mounts. They're made for RZR's
and the clamps are 1.75". They fit the EVO tire carrier as they are the same dimension (I ran out & measured before I ordered). Very well made. The ring
clamp is welded on all sides to the mounting plate so it looks plenty strong. I tried a couple different places and they all work well although some places blocked
the rear lights. They are easy enough to mount that you could mount & unmount in a few minutes if you want move around. They don't fit the rollbars though - those
are larger diameter tube. They're not cheap at $37.50 each, but they are a great option.
