Cpfiremn
Regretting this purchase part 2
I had my rig on the lift the other day and I noticed that at full droop, the shocks seem to hold the axle and prevent it from dropping any further, so what are the benefits of disconnecting the sway bar links on the trail.... Let's hear it Ladies...![]()
I noticed you have bilstein 5100s. When your teraflex budget boost was installed did you replace those shocks with stock height bilsteins 5100s or 0-3" shocks. The 2.5 teraflex BB come with shock extenders so you can use your OEM shocks. If not then you may have to purchase longer shocks because the OEM shocks can only extend a certain amount of down travel, limiting the articulation. Also if you have not done so yet. You may want to extend your front brake lines, so you don't rip off your brake lines at full flex
