Axles 950..trusses950.....gears lockers and compressor 2600...tone rings 50...brakes 600sweet lookin' axles! how much do you think you've had to put in total for them?
I have the 3.6....got to see how it does with these heavy axlesNice looking project!
Question to the folks who did this swap. Did you also change the engine? My JKU has that old anemic 3.8L and it would have a very hard time spinning these guys.
Sent from my SAMSUNG-SM-G891A using WAYALIFE mobile app
At the risk of sounding stupid, why would you need to truss 1 ton axles??
Not that I'm an advocate for trussing an axle but you can still bend one ton axle housings. Specially factory ones. I'm not saying a truss will help that.
I'd post some pictures but my phone isn't letting me but so far I have the artec 1ton swapkit, Artec 60T tone rings and sensor mounts,ruff stuff cover, grizzly locker, 5.38s,1350 yoke, install kit, rotors and pads.
Just waiting for the abs stuff and pinion yoke to get delivered.
Pretty excited to get it all cleaned up and welded up so atleast it will start to look like progress!
Artec tone rings and dodge abs Sensor works for the front ford d60. I just need to find what part number it is . And any aftermarket programmer can help you correct SpeedoWhere did you get your ABS stuff? Also did you have to do anything with your JK's computer for the ABS to continue to work?
Sent from my SM-G955U using WAYALIFE mobile app
Depends on the axles and tone rings used. If you swap to a front superduty 60, you'll most likely match the rear to the front's tone ring count of 60. Due to the change on the tone ring count from 52 to 60, it is required to set a nonstandard axle gear ratio (e.g. my 5.38s are set for (52/60)*5.38=4.66). This also requires a change to the tire size to get the speed correct and it's not the tire size of the tire. In my case for my 41.5s it's somewhere around a 34" setting in the computer. If you don't do this, the Jeep may freak out and put you into limp mode which happened to me before i set the correct ratio.
To make that change, I had to use an older black and white Superchips Flashpaq. I've heard the TrailDash2 will allow a non-standard gear ratio. Most other programmers - AEV Procal, Diablo Trinity, newer color Flashpaq/Flashcal will only allow you to set standard gear ratios (5.38, 4.88, 4.56, etc). So you gotta be sure to get the right programmer.
There's a reason I do ultrasound for a living and it's not bc if my mad math skills. Do you have some sort of equation to calculate which gear ratio and tire size to program into the programmer?
The programmer does it for you you just follow instructions. Well that's how superchips works anyways. All you need is a tape measure to get actual tire size.
