I don't have the procal I have the Superchips Trail Dash. Actually won it in a givaway they did last October. Guy called me and I![]()
well than you should be fine sir as both are good products...
andrew -
Not to highjack but does the trial dash do a better job of reconfiguring your jeep for 35's than the aev procal?
I saw another post where a guy had the procal and got 35's and his jeep drove horrible. I want to make sure my 2010 automatic will still be a functional dd with 35's.
I don't have the procal I have the Superchips Trail Dash. Actually won it in a givaway they did last October. Guy called me to say that I had won and I![]()
Hmmm. I'm pretty sure the GPS antenna is on the sport cage so I'm not sure why it would interfere. The directional antenna is under the lid of the dash so I could see potential interference there maybe.
I have a question on this programmer, did anyone buy it and has the my gig navigation system from the factory? Also did it effect anything with it? I mean did it mess up any of the navigation program or vise versa in the 2011 or newer?
Yes I have it on my 08 with factory nav. No if you follow the directions and move the module and place it like they show, I didn't have and don't have any issues with the nav or compass.
So I just went and messed with mine. I don't use my nav unless I am going out on trails, and even then I have an iPhone app that's much better.
I looked and it said I was in woodland park Colorado, which is probably the last place I used the nav. I had 0 satellites. I drove around the block with the dash part off and it picked up 6, then I put it back on and went to 0. Once it picked up the 6 it corrected itself and even with the dash back on, it was fine. I drove around the block again and it was still correct and showed the right street names. Honestly the dash is more useful to me then the nav itself. I use PDF maps by avenza, it's a free iPhone and iPad app, and has a map store with MVUM maps for Colorado. They are free, and what this allows you to do is plot your trail heads, then use the apps built in GPS on the trail to determine where you are. You can even import/export between devices so you can give it to all the jeepers in your group. works on android too.
Here are a couple stock photos of the RR bar I use as a mounting point. I just ditched the cheap plastic trays the photos show.
This bar could make a great mounting point for the Traildash too if you aren't interested in removing your upper dash panel and relocating any of your nav equipment.
Hey Hack12 I've been thinking about doing the same thing; using the RR bar as a universal bar mount (without their trays) what is the diameter of the bar? Any pics of how you used it?
The bar is about 3/4" in diameter, though I haven't done any exact measurements. I am currently waiting for the Ram Mounts I ordered to arrive, tracking is showing Tuesday, 2/4. I am running the bar alone now, I just can't believe it took me this long to think of using it as a universal mounting platform. As of Tuesday, I will have my GoPro mounted in the center to record video and my iphone mounted on the driver's side to view the video in real time. I'll post some pics as soon as I get it all set up.
Exactly what I was thinking about doing, :thumb: just hadn't pulled the trigger on the RR mounts...was going back and forth about buying the system if I wasn't going to ever use the trays (would love to by just the bar and mounts it they sold it that way), thus hadn't spec'd out bar diameter to compare with RAM mounts. :naw: Thanks for your list as it will be a good starting point for me to figure out how I want to configure.
Was thinking Trail Dash to the left, GoPro in the center like you mentioned and possibly a separate GPS unit somewhere along the run (don't like the factory one). Would love to see some pics once you get it installed. Let us know how it goes. Good luck with it all.
