phillypete
This could be the issue, but since he put all the sensors in the rear I’m assuming he went with 52 count rings instead of 60.
Yes 52 count on the rear.
That is exactly what this Artec kit does. I saw nothing in the documentation that it would not work on 2012+ vehicles.
I’m pretty sure he’s right and most likely this is the issue. You need to run speed sensors at every wheel. It’s not a big deal other than the fact that you already put 52 tooth count rings in the rear already. You’ll either have to change those to 60 count, replace the front unit bearings with the Currie unit bearings built for JK’s, or rebuild your current unit bearings tone ring with the ones Artec sells. You’ll also need abs sensors for a ram pickup.
