JT@623
So long story short after the coil over install the bump stops on the front axle didn’t line up the axle rolled back a bit . I finally got around to checking the castor was at 13.7 degrees adjusted it back to around 9.2 degrees. Bump stops and driveline is straight.
So now the steering wheel is off center to the left and there is no more adjustment in the drag link to center it back up . Any thoughts .
