Where in the gear box is the adjustment to tighten the steering. Thank you
Maybe I'm missing something but, what do you mean by tightening up the steering? What exactly are you feeling?
On the RHD 3.8L JK's its under the airbox.
If you follow your steering column under the hood from where it comes from the cab, about 2 - 3 foot down the column it joins at the steering box, ontop of the steering box you will see a nut with a Allen key bolt in the middle.
You loosen the nut and turn the allen bolt.
It highly not recommended to do this and I was a fool trying, I havent had issues.... YET :shock:
Good luck
The steering feels loose at highway speeds
So a front alignment should help
Not exactly - more positive caster will help BUT, that comes with a double edge sword. Too much positive caster will lead to drive line vibrations. You need to get to at least factory caster which is about +4°. BUT, even at that, you may still have flighty handling due to your ram assist.
Either way, this is something you should do yourself. Taking your jeep into a shop will just be a waste of money.
Do you have any steering issues like this on moby
Okay, that helps a lot. Sounds to me like you have too little positive caster. That's where you should be focusing your efforts.
Sorry for the hijack but my steering likewise has been really loose for the past 4-6 months or so, but I have all factory suspension components so my caster shouldn't have changed. Any suggestions there?
Don't forget about checking the pitman arm for play and the nut for proper torque.
Maybe I'm just being paranoid and reading too much into it
