TrainWreck618
Well ok then....
I will not be attending either. You guys have a pretty good crowd growing don't you?
Well ok then....
Yeah, we're up to around 62 total at this point. But the run groups will be around 8 rigs per group, so even though we'll have a big group to hang out with, the trails will be a smaller group of rigs. Luckily the park is MASSIVE.
Wow.. thats a lot of jeeps! I haven't made it down there yet but I hear the park is really a great place to spend some time
Hey guys, just wanted to fill you in on what was figured out. Had to grind out and completely re weld the track bar mount. View attachment 209221 Also need to order a new passenger side lower control arm as mine is shot.. Im guessing the jam nut came loose and it all went down hill from there. Everything else is solid nothing bent, but I will be holding up on hitting anymore trails until gussets and ball joints can be replaced. I feel like I'm pushing my luck with these heavy tires and wheels every time I hit the road.
If you need just a factory front lower I have one I'll give you. I replaced mine a while back. Bushings are fine.
Sorry I didn't get to hookup with you guys. Wheeled with a local group and had a blast. Stayed on 3-5's all day and definitely got my fix. SMORR was awesome. Did Redbird on Friday and it was fun but just cruising trails.
Well ok then....
SMORR is a blast. Did you guys do rocker knocker? Flex n stuff? All the creek beds are fun to explore. I had to miss due to wedding anniversary.
Any of you local guys plan on going to jeepstock this year? It's at SMORR
