I’ve been running the 4” Full Traction long arm kit with a set of 37” Falken Wildpeaks on my JKU for almost 2 years. Here is a short list of some of the trails it’s been on: Rubicon, Several trails in Moab, Clawhammer (Hammers), Dishpan, Bullfrog, Holcomb Creek, Last Chance Canyon, Nightmare Gultch and Swamp Lake and most recently Sidewinder trail along with many others, some numerous times.
The Jeep has run this lift for 32000 miles and only one thing broke. The left front lower control arm Clevite bushing on the cross member side failed. Repair cost $20. This included $6 for the bushing and labor to have it pressed on the control arm.
Overall this kit has performed well and I have been very happy with it. Steve at FT has been very good to me and I appreciate all the time he spent explaining the benefits of running his long arm kit. Here is a list of the pros and cons I have experienced since the kit was installed.
Pros IMHO:
1. Extremely Durable
2. Good handling for a coil spring suspension
3. Good ride characteristics on the highway
4. Good flex for a coil spring suspension
5. Low maintenance cost
6. Completely bolt on kit
7. Absolutely no bump steer
Cons IMHO:
1. Rear lower control arm brackets hang down too low. You will be dragging them over rocks at some point. However, they have held up well and can take a beating.
2. You will lose about 2” of ground clearance at the cross member compared to some other lift kits. This is because the kit comes with a new cross member that the front lower control arms bolt to. However, the cross member comes with a skid plate that offers excellent protection to vital suspension components and the cross member. The skid plate is available separately if you ever need to replace it.
3. The kit comes with a drop pitman arm. Two problems I have personally experienced with this are excess stress on the sector shaft caused the sector shaft bushing to wear and develop side-to-side play. This resulted in a loose feeling in the steering and a slight fluid leak when turning under extreme off road situations.
Your Jeep will be extremely hard to steer when crawling over rocks. :yup: I have since upgraded the steering to a PCS ram assist and installed an EVO sector shaft brace and love it. If you decide to get the kit, talk to your installer about a drag link flip kit. Either way you go, eventually you will want to upgrade your steering. It makes a huge difference, believe me! Very important. Regularly check the pitman arm nut torque. The nut WILL come loose over time.
Other items I recommend you consider (with and lift kit you buy):
1. Lower control arm skids (axle side)
2. Front axle gussets
3. Front axle sleeves or backbone truss
4. EVO engine oil pan and trans pan skid plates
This pic will give you and idea of how much flex to expect if you run a set of Bilstein 5100 series shocks.
I’m currently saving money for the EVO bolt on coil over kit because from what I’ve seen what this kit can do on the trail and what I’ve heard on how well the Jeep rides after having it installed, my back will thank me.
Good luck with your Jeep and post some pics. :thumb:
