Andy5160
:yup: Its so smooth I can drive with one hand and text with the other!
Next time I see you I am taking it for a spin
Installed my long arm 2 weekends ago all I got to say is I should have done it sooner. The on road ride significantly imoproved!
For sure, but it may turn out to be a fairly expensive test ride - you're gonna want to do a LA kit if you drive it! :crazyeyes:
There is another component to going long arm in addition to on-road comfort, which has to do with how leverage is applied to the suspension system, the effects of pinion angle as the suspension cycles and roll center to name a few. There is a lot of math and even more opinions on how best to apply that math. Unfortunately, the packaging of the JK limits the ability to traingulate the rear without going to a rear mounted fuel tank and substantial fabrication. The good new is there are people who do this for a living that have found a nice balance from all out race to road comfort. Look at the Evo DTD for more of a race suspension system and the DD Pro long arm for a budget minded street / off road system.
I think I saw your build thread, but can’t recall - did you do the high mount set up?
Not necessarily. You can have long or short 3 link suspensions as well. What matters is the geometry and its effect throughout the suspension cycle. There is no single perfect design. What works for desert racing may not be the best for crawling and so on.
I haven't seen a 3 link setup that's better and more affordable than the DTD, or that has been tested as much. Regardless, why are we talking about 3 links? I thought this conversation was about short arms vs long arms?
[emoji23][emoji23] anytime someone brings up three link set ups I just laugh. Have fun being stuck in the middle of no where or the farthest part of the park and try to drive your Jeep out to your trailer or even back home
I am with you there. It's a catastrophic failure point.
Yet you brought it up, and think it's a better system.. it just needs more fabrication?
