Interesting. Never thought of that. Maybe I'll check out our local Sportsman Warehouse. I need two at 22" and two at 12". This is what it looks like.
I know the local SW custom cuts arrows.
As long as you can find tubing that will fit snug on the arrows, I think it would work. If you already know this, forgive me, but another thing worth mentioning is the called the spine of the arrow. Arrows are made differently depending on the draw weight of the bow they're going to be used on. Basically, higher the draw weight requires a stiffer arrow. The differences may be negligible since you would need a relatively short length of it though. You could always take a couple out of the box at the store and flex them a little. Take a look at either a 250 or 350 spine.
Right now, one holds a tire repair kit, another a 36mm impact socket, the third holds TP, and the fourth is empty.
The ultimate plan is to stock these with often used items. Maybe first aid, tire repair, tire inflation, headlamp, hammock. I'll play around with them a lot to figure out the best combination.
Edit: forgot water filter and/or purification tablets.
Getting closer to a pretty solid set of tools for the trail. All of this fits under my deck on one of the long cubby sides.
I can't see anything with that massive shadow.
I guess I can leave my tools at home now. Thanks Sharkey.![]()
Nice. Brings a tear to my eye. Something special about organized tools in the back of a Jeep. A sense of pride is present.
