Andy5160
Spacers installed, leveled everything back out from the weight of the bumper and winch. I got lazy...and didn't have tall enough jack stands to raise the jeep enough for the Axle to droop enough to get the spaced springs back in, so I went out and bought a set of spring compressors. Necessary...no, more dangerous...yes. It did made quick work of the install though.
Sway bar links defeated me. The evo HD links have a threaded portion off of the heim joint that feed through the hole in the sway bar itself...but the hole on my bar is ever so slightly too small for the new links for some odd reason. Attempted to enlarge the hole using a shitty harbor freight drill bit and ended up making the bit smaller as opposed to the hole larger.
In other news, I bought a new echo weed whacker and its total garbage. It's going straight back to Home Depot.
Catching up and sorry to hear about your shaft/s
Which one you're getting?
