spinuck
This is the stuff I used to reassemble with, worked amazingly well, that on all the gear faces and anywhere metal meets metal seemed to work best. Then a good quality gear grease (I used the valveline semi synthetic). Hope you can figure this out. I will say that personally the No Limits disconnect is the way to go once your electric motor kicks the bucket tho. Just throwing that out there.
I probably will get the No Limit while the motor is still good, and try to get a few bucks for the motor. I'll try the oil/grease you suggest and see if that helps. Thanks for the input. :thumb:
