I still like certain wheels in black, but like we talked about these Chamber Pro II's out at pit stop #8, the machined finished on these are just badass! Nice change from the black wheel crowd![]()
I really like your jeeps Eddie. They are all works of art, Simple but highly sophisticated machines built with a purpose in mind.. to go to the mall![]()
This picture looks awesome! It really shows how dozer looks orange and yellow. Nice job Cindy!
Thanks for the great pictures, jeep looks amazing. Can on imagine what it's like to bomb across the desert in that beast.
Hey Eddie do you have an updated build list I know you changed from bolt on to the double throw down?
This list should be about current:
• EVO Double Throw Down Coil Over Kit
• EVO High Clearance Long Arm Kit
• EVO Draglink Flip & Front Track Bar Relocation Kit
• King Rear Air Bumps
• Dynatrac ProRock 60 Full-Float Rear Axle
• Dynatrac ProRock 44 Unlimited Front Axle
• ARB Rear Locker
• 37x12.50 Nitto Trail Grapplers
• ATX Chamber Pro II Bead Lock Wheels
• 1.5" - 5x5.5 to 5x5 Front Axle Wheel Adapters
• 1350 JE Reel Drive Shafts Front & Rear
• EVO 1/4 Pounder Front Bumper
• EVO MFG Vacuum Pump Relocation Bracket
• EVO MFG ProTek Skidplate System
• EVO Rocker Skins
• EVO Rock Sliders
• EVO Rear Tire Carrier
• Truck-Lite Complex Reflector Optics Design LED Headlights
• Truck-Lite Driving Lights
• WARN PowerPlant 9500
• Rock Hard Sport Cage
• EVO ARB Compressor Bracket
• ARB Compressor
• Odyssey Battery
• Cobra 29 PLX CB Radio
• Firestik II Antenna
If I can think of anything missing, I'll be sure to post up again![]()
• ARB Rear Locker
Thanks awesome build. Looking to do some very similar drive train/suspension mods on my 15 anything you would do different?
Rubi Components/Locker in front?
So the PR44 is the same width as the stock front 44? Is that the reason you need wheel spacers, as well as bolt pattern?
Quick question. I am looking at getting the bolt on kit next year but won't be able to upgrade the axles at that time. I want to run 37" tires and if I upgrade the gears to 5.10s (live in Colorado) and weld on the gusset reinforcements, do you think that will be sufficient for the time being?
Curious, why does your name ring a bell? :thinking:
