Chapco
I just installed a RK 3.5 Flex kit (short arm) on my 07 Rubi. Added the extended brake lines too.
Did it over July 4th weekend so no one was around to help.
At some point I will write up the steps. (added on page 2)
Very very happy with results. Rides over some big stuff with ease.
If you are considering this, it is pretty straight forward, but the instructions lack a few experience needed tips, like which coil to put in first on the front end so you don't have to fight or compress it. Install bump stops in coils loose and crank in later. Rotating the front drive shaft to meet the new control arm lengths, installing brake lines, and adjusting the steering wheel to keep the ESB from triggering braking over bumps. How is gearing affected, how to drill out your sway bar holes for the new linkage bolts.. What to do when you do something wrong..
Fortunately most of these things can be found here in the forums.
Send me a message if your considering doing this kit on your own and I would be happy to answer questions from my experience.
