2Cross
Father of the year. Good job.
Lol
If only
Water pump ordered and thermostat. Hope to install next week.
You sure have one lucky kid. Sounds like his Pops is teaching him right. Make sure he gets under that hood and learns everything along the way.
Big congrats to your son for Eagle. That's a hell of an accomplishment
Much improved but still gets warm on long slow climbs. Used to overheat super fast so I know it helped.
Any advice? Thinking I'll put dual electric fans with a shroud.
Right now it has a 850cfm fan. I found a shroud that will fit two 1000cfm fans
I checked the radiator with my laser temp gauge and it cools about 10-15 degrees by the bottom. Is that enough ?
Edit- gauge is working correctly
Run the laser up and down the core rows and make sure temp stays fairly constant. It will change a little. If there's a blockage, you'll know. It will be a large difference in temp. If that is good, my best guess is looking at air flow / shroud ideas.
Good job man[emoji106]what's next?
50 miles on the new ignition and is running better. If it makes it to 250 miles will start taking it off road.
