Update on the jk. Continuing the build. Slowly coming together finally.
Build sheet re-updated...to a more current set up. I know i am missing a lot still
Power-train
Custom built 5 speed transmission (swapped instead of the 42rle)
3.8L (being swapped to a 3.0L diesel)
Dynomax Pre-axle dump exhaust
4.10 gears (stock)
Suspension
Full Traction 4" coils
Currie Rock Jock Upper and lower front control arms
Currie Rock Jock Upper and lower rear control arms
Synergy Rear Track bar
Full Traction Rear Sway bar links
JKS adjustable front track bar
JKS Front quick Sway bar disconnects
Synergy drag link w/flip kit & solid rubber boots
Synergy tie rod w/ solid rubber boots
Synergy Rear bump stops
3/4" terraflex spacers f/r
Fox 2.0 Reservoir Shocks
Synergy front upper track bar brace
Synergy front track bar relocation bracket
Synergy rear upper track bar brace
Synergy rear track bar relocation bracket
Synergy steering stabilizer tie rod clamp
Synergy steering stabilizer relocation bracket
Synergy sector shaft brace
Fox steering stabilizer
Synergy 1.25" wheel spacers
Wheel & Tire combo
Synergy 1.25inch wheel spacers
Razor 17 inch rims
35x12.5x17 Goodyear Mtr Kevlar
Armour
Custom oil pan skid
Evo rear corners
Ace rocker guards
Lighting
Rigid 50 inch LED bar
Stock fog lights
4 Riged Cubes with clear lens
2 Rigid Cubes with amber lens
2 Rigid Cubes with clear lens (reverse lights)
Trucklite Tail lights
Green LED Floorlights F/R
4 ANZO LED pods (f/r over axles as rock lights)
Amazon 12inch led light bar mounted to bull bar
Bumpers
Rugged Ridge Modular Bumper w/bullbar
Evo rear bumper delete fascia
Evo rear frame shackle inserts
Evo rear tire carrier
Accessories
Rugged Ridge A-pillar switch panel (all lights wired in pairs)
Daystar Center console switch panel (all lights wired in pairs)
Sensor read out clinometer
Cobra 19 CB radio
Unknown brand PA Horn/speaker
Roll cage mounted fire extinguisher (rear)
Under seat mounted fire extinguisher (front)
Hi-lift hood mounts
Rugged Ridge grab bars
Rugged ridge mirrors
Paracord secondary grab handles f/r
12000Lbs Mile Marker winch w/Dynema synthetic line
Engo Winch Cover
Engo aluminum hase
Roll cage trail axe mounts
Ace rear licence plate relocation plate
Evo tailagte tramp stamp
Evo rear cb whip mount
Front license plate roller mount
Rugged Ridge Foor Mats
Rugged Ridge X-Clamps
Rugged Ridge Hood Louver
AEV Snorkel
Alloy USA Axle Seals
