MattAlpha
As several members told me about a year and a half ago...you will have exhaust leaks, higher engine temps, bolts will loosen and spark wires will be burnt IF you install headers. All of these things have now happened to me since I installed my JBA headers except burnt spark plug wires. That happened today now that my exhaust wrap has began to fail on my drivers side.
You can see in the picture that I had to zip tie the partially burnt spark plug wire up away from the manifold so that I could drive my rig home. I have a spare wire but I need to fix the source of the problem.
So I’m going back to OEM Exhaust manifolds. Aside from sharing my header experience with other members, I need some advice on which OEM manifolds to buy. I know that may sound strange, but there are two listed on MOPAR parts online (for both the right and left sides):
Right side: 4666026AC - $90.71 or 4666026AA - $25.13
Left side: 4666024AF - $90.71 or 4666024AB - $29.99
I tried to call them but it is after hours on the east coast (5PM).
Anyone that can tell me the difference? I would prefer to pay the lower amount if they are the same parts. BUT if the higher priced manifolds come with the heat shields and fasteners, then I would buy them because I threw all of the OEM stuff away because the JBA kit came with its own hardware minus the heat shields.
Thanks!
Thanks!
