Speedy_RCW
Hey guys,
As I mentioned in my build thread, I just had my 4.10's swapped with 5.13's on my JKU and now have what seems to be a driveshaft vibe. I thought it was coming from the front since it's an aftermarket CV shaft (with less than ideal pinion angle) so I pulled it and still have a vibe that starts around 45 and seems to clear up at 60. Don't wanna go up past 60 while i'm breaking in the gears. Since I'm not entirely sure it's only the rear vibrating I still need to mount the front back up and remove the rear and take it for a drive to verify. But my question is in regards to the rear shaft vibration. Should I get rear UCA's to bring the pinion angle back to stock or just spring for an aftermarket shaft with stock arms? I'll eventually do both but can only do one right now as budget is limited. Eyeballing it, the pinion angle looks pretty ideal for a CV shaft. Being that I installed 3.5" suspension with stock rear arms the pinion looks tilted enough to be pointing right at the TC output but I haven't put an angle finder on it or anything. Has anyone else experienced driveshaft vibrations with the stock shaft after doing gears? I don't know shit about the rzeppa joint but thought angles weren't as critical with it for some reason. Anyways, thanks in advance.
