Primo82
Pretty straight forward. Install everything where you want it. At the radio hookup the swr meter ( or if it has one built in) go to channel one press the talk button and watch the signal strength. Repeat with the high channel. Assuming you have a tuneable tip, spin it one way or the other replace tip cap. Repeat. If you keep getting way high readings your ground sucks and needs attention, that’s where a grounding strap comes in. Make sure everything that’ll be installed on the Jeep is there when you tune it, tire carrier etc.
Here’s the how to i follow
https://www.rightchannelradios.com/blogs/installation-guides/18330687-cb-antenna-tuning-instructions
Here is his write-up for the Cobra 29 in a JK.
https://wayalife.com/showthread.php/5699-Cobra-29-CB-Radio-Jeep-JK-Wrangler-Installation-Write-Up
Here is his write-up for the Cobra 29 in a JL.
https://wayalife.com/showthread.php/54093-WAYALIFE-CB-BAR-Jeep-JL-Wrangler-Overhead-Full-Size-CB-Radio-Mount
Edit: I misread your post and did not see the "set up a CB" part...haha. Hopefully you'll still find this helpful.
Thank you for the links! It seemed easy enough. I tend to like to over educate myself before digging into something new. Appreciate the help.
