DWiggles
that i got..i understand what your say.
but when you say "Pinging isn't just a noise, what's happening is the piston isn't able to move through the stroke at the same relative rate to match the expansion of the fuel mixture (compression ratio), as a result, this is excessively loading crank bearings, this term can also be known as "detination" ... this is the part of the post I would generally explain in technical detail what's going on, but being that the OP believes he can benifit without contribution I'll let him do the leg work"
is the noise in the crank bearings or being translated to somewhere else like the rockers etc.
i appreciate the help.
http://lmgtfy.com/?q=Engine+Pinging
:thinking: :naw:
