Trail Jeeps just posted this on Instagram. I have to say, I usually don't like bright polished wheels, except on black, dark blue or red Jeeps, but those are SEXY!
So yesterday I was on my way to work and my steering went out. Thankfully I could safely get off to the side and found that my track bar is slightly fudged up
Im about to flip my drag link this weekend! What happened? I see the nut broke loose, was it cotter-pinned? Did it oval out the hole?
You mean drag link? How did that come out? Glad you made it to safety.
Yes I meant drag link. Idk why I put track bar. But I have no clue. I noticed the other day my steering was very loose and had a lot of play in the steering wheel.
I hit a bump on the way to work and lost my steering. I have no clue how it happened or what caused it. I was taking it to the shop today to get it checked out but ended up having it towed yesterday since it wasn't drivable
It's an evo kit
It's an evo kit
So I assume the nut was completely gone then when this happened? How long ago was the flip done?
Yeah it was nowhere to be found. It was done about about early june
So maybe a month and a half ago
I wonder if it ever got tightened? Some of the tapered connections I've taken apart you wouldn't think would come apart even without a nut
Did you do it or a shop? If shop, then they should take care of it.
Done at a shop at the same time I did the enforcer and axle swap. I talked to them and tried to keep my cool and they made it sound like it was my fault that I didn't double check it.
Yes, I should've double checked everything and I did check many things, just didn't think I would have to worry about something that is fairly basic...
