H8ROADS
My experience (with the Quick Disconnect that is) has been pretty bad. I had read that they come apart after a while. My situation was that I could not get a good ground out of the thing, and such, my SWR was very high. I also understood that the quick disconnect will accumulate water and then eventually rust. The old ones used to be really good, but the new ones are not made as well (read Chinese) and failed after a short while.
I simply unscrew my Firestik II from the mount when I want to park it inside. It is easy and I get a much better transmission with a SWR of almost 1.1!!
As for the wife, super happy with her.
If your swr is high then you obviously haven't tuned it correctly. Ive been running quick disconnects for years with no issues at all. As long as you tune your setup correctly and with the disconnect in place, there should be no issues at all.
