If that's true, I'm glad to hear it.
Ideally, you really want a ram to be mounted to the axle and have it pushing and pulling at the knuckle but most Dana 44 setups today have it mounted at the track bar mount and having it push and pull at the tie-rod. If you're running a factory tie-rod or one that isn't up to the task like a Metalcloak, your ram will exert enough force to bend it. This is a problem I've seen time and time again. With a tie rod that is strong enough like a Currie, you will be fine.
Also, if you have big flex, you really need to keep an eye on your hoses as over time, they can chaff against each other or on other components and over time, can fail. A compromised line isn't the end of the world but if you don't have a spare or don't have the means to cap things off, you are going to be left without any power steering. This can be extremely difficult to drive especially with big tires and/or on the rocks.
