BigBoy
I did a search but couldn't find a definitive answer. I'll preface this with I have a sport and I'm wanting to upgrade to larger tires.  I've read MANY TIMES that the ring and pinion is the weak link on a D30 and that the D44 is essentially built the same but with a stronger ring and pinion. That being said, does the prorock 44 have the same ring and pinion as a rubicon D44?  I wheel mostly sand dunes so the axle strength of a rubicon D44 may be enough if the pinion strength is the same. Purely thinking about not if, but when the D30 may fail on larger tires.  Not sure I would need beefier tubes and such for dunes. Thoughts?
		 I live in the PNW so we do have some trail areas but I've never really been into that. We make it to the dunes more often than anywhere else. Up to the mountains for camping and fishing trips, but that is usually on a logging road of some sort.
