They are surprisingly super fast to fill tires and it does not need any downtime.
I agree with this. Strong, no downtime and fast, which may be the only time you can use those three words together to describe something that is "good."
1) When the pressure switch shuts off the compressor it also shuts off the winch! They use the same motor. The only difference is the manual lever that moves the drive gear from the cable drum to free wheel vrs driving the drum. You will have to find a way to leave the compressor open so it can't build up pressure.
Are you saying that the winch won't run unless the air tank is empty?
You have to bleed pressure off before you can winch? Is there a bleed valve or something or do you have to connect something to where the hose attaches and bleed it from there?
it does not have a check valve, as soon as you disconnect the hose it will empty out, it also has an overpressure valve for when you are using it, but you would most likely remove any hose you are using before winching
To all of you thinking about running an auxiliary tank you will have to figure out a couple of things first.
2) That also means that you will have to find a way to keep the air already in the tank in the tank so it won't drain while your winching somebody or yourself.
Hope this helps.
I noticed on the PPHD 12, that the built in tank has plumbing going and coming from it. I was thinking of just removing the small half pound tank then run the plumbing to the larger 2 or 3 lb tank. In theory it should work. The difficult part would be looking for somewhere to mount the tank under the jeep and send and receive the plumbing.
That would work, you just need to make it think there's no pressure.
Yikes. Seems like a pain to have an additional tank for what I need it to do.
I understand why Warn designed it they way they did. Simplicity and safety.
I think for my application I'm going to run a winch and separate air system with a 2.5gal tank.
I need a reserve of air at all times.
Thanks for all of the info guys. This really helped.
