JMFK
For what it’s worth years ago I put a Dana 300 transfer case into my CJ7 that I bought refurbished by a company called Novak. When they assembled it a brass bushing wasn’t properly installed which caused a lot of slop for which ever gear it was supposed to be on. I don’t recall exactly what shift pattern cause my sound but it was similar to the “ping” you heard. I’m guessing the gear was loose enough that when I shifted it didn’t slip into place nicely it more hammered into place. Your video kinda shows the same thing. The drive shaft has a quick rotation then rebounds with a ping. My issue was deeper than just the ping though because the bushing was just loose on the inside of the tcase and the grinding it caused was way worse than the ping. Hopefully the dealership will just replace the tcase for you and the problem goes away. Good luck.
