tylerbrinks
I have a 2017 automatic JKUR which has had a CV drive shaft for about 3000 miles. Just recently I've been getting this ringing noise when I shift from 4lo back to 4hi. The sound is almost certainly coming from the drive shaft because:
Here's a short video shifting from 4hi to 4lo demonstrating the issue:
https://streamable.com/s/uu6ro/lsdktp
For what it's worth, it also happens occasionally when shifting from Park to Reverse or from Drive to Reverse.
I can't tell if it's a problem with the T-Case, the drive shaft, or something else in the drive line. I really need some good advice or ideas on this one. Thanks a million for the help!!
- Tapping the drive shaft's body with a wrench yields the exact same sound.
- I removed the drive shaft from the t-case and the noise doesn't happen when it's disconnected.
