PIGINJK8 build
If you don't want to incorporate the rear roll bar, you might want to look at the way softoppers makes roll up tops for K5 Blazers. The frame system mounts to the bed rails instead of a cage.
Thanks for the idea. Factory roll bars are dirt cheap from mopar. My idea is to make it a bolt on part, so I can easily go to the half cab when I want. Once the factory bars are in place the top will fit like any other jeep. Since I already figured out the rear half door upper, it'll look perfect.
Just borrow that until my EVO pro comes in[emoji106]
If I were to change, I'd go with the EVO pro front as well. Wish they had come out with that sooner. Though now with my cage I need a full stinger as I can't see the front of my Jeep. I have SMD (short mexican disorder). LOL.
Short Mexican? Are you drinking again?
Finally mounted the Walker Evans beadlocks on a set of 35" nitto mud grapplers, thanks Adam.
Installed ball joints to fix the wobble as well.
