I got the winch all fixed. One disadvantage of a synthetic rope is it gets wet and stays wet in the winter. Of course around here that means wet with brine. The Zeon drum is aluminum. No match for today's road salt.
Couldn't remove the puck, and since I decided to replace the drum I cut off the rope.
Of course me being the dumbass engineer I pulled out the drum brake without instructions which ended in a yard sale of parts. Warn helped a lot here; I ended up ordering a few repair kits. Drum, brake kit, and top buss connection kit. All in with the new rope it was $500. Almost half the cost of a new Zeon.
But warn helped me re-assemble the old brake so I at least have a bunch of usable spare parts. I also now have the nerdy neoprene cover. I suspect it will also stay soaked, but it should be cheaper and easier to repaint the exterior vs new drums. All back together yesterday, mounted and tested.
Now for the new plans:
Rear EVO Lever
Rear DTD
Rear semi-float 60
Front PR44
ARB lockers
Big brake kit
On board air
Sometime down the trail I will convert the front from bolt-on to DTD. I spent way too much time debating between PR60/FF60 and the lesser PR44/Semi above. In the end it came down to not needing the extra strength, cost and wanting to keep my 5 lug wheels. I may at some point swap motors, but not before I stop using this as my DD and especially no more winter driving. The air was free with the two lockers, so I will have that along with the portable Viar as a backup and for friends to use for airing up.
It will be a while before I can start all this given my travel schedule, but I want to be done and dialed in for an October trip to Albuquerque, Santa Fe, Durango and Moab. Thinking I will ship the Jeep out then drive it back.
