Orion
Did you get er done?
It’s all up in there... just need to grind 2 of the “Bolt Skids” for fitment at the stock T-case skid, then tighten everything... Then I’m going to see if I can get the lower control arm skids welded in today. (Unless somewife or somekids throw a wrench in my plans... lol)
Cobra 75 installed today... went pretty smooth.
Went through the Vent:
Fiber wrap to match stock:
Lifted the hardtop a few inches for room to easily run wire at roll bar:
Zip tied the brain... nice and solid:
Planned on mounting coupler to the bottom of the dash panel.... but instead put 6” of rubber fuel line around the cable & coupler and zip tied it to the metal support... very solid & cable protected:
The cable tucks quickly under the console, then hooking a couple loops takes the stress of the coupler when in use:
Power wire through hole in cab and to the battery:
Calibrated:
Ready for use:
Calibrated:
Ready for use:
Nice job! Where did you get the cloth wrap for the wire? I like it
The Build & Travels of ORION
Safety install today... got the Fire Extinguisher mounted... I only had to drill one hole in the bracket and use the factory holes in the seat frame.... The Extinguisher came with a plastic brace so I bought the metal one for better support.
Feels secure & pops out easy...
Quick Day/Night Trip out to Cal City with my 2 boys... The Desert is so Peaceful. The Jeep feels so at home there... Got to test out my RockHard skids & the ARB Twin... only problem was we had to come home... [emoji481]
Adios Los Angeles!
My oldest tearin up his 50.
Youngest gettin comfy on 4 wheels
Jeep took us up to some great views.
I have no idea...
Desert Sunset was bad ass!
Youngest prepping for Baja...
Desert Sunrise... Headed Home :(
