TrailHunter
I'm pretty sure it's being 100% funded by parking fees at the Coliseum... $75 last time I went to a Rams game.
Lol... Probably.
Took my Son to see the Rams new Stadium.... pretty cool.
The stock rear lower arms have been bugging me since I put the stage 2 enforcer lift on... Simple upgrade to stage 3:
Stock arms look like a #2 pencil next to EVO’s..
Much Better.
Much Better.
Blew the large 40amp Maxi fuses on the ARB twin last week... been racking my brain trying to figure out why... checked all the connections and everything is fine... through in new fuses and its working fine. I thought the motor stalled when the fuses blew... But now I think I forgot to start the engine while running the compressor and the battery drained... causing resistance and strain on the fuses...
Any chance the positive feed wire rubbed on something metal somewhere?
ARB does a pretty good job of protecting those wires... I saw no pinches, or rips in the protective covering. If it happens again, I’ll be removing the whole harness and the wire covers.
Sounds like an over-current condition if you were running the compressor with the engine off. As the battery voltage dropped the motors need to draw more amps.
Sweet pics. Crazy how much snow everyone's getting.
3rd try on the stabilizer... The Fox 2.0 was still pulling enough to annoy me.. This Rancho 5000 shock is perfect.. Swapped in the 1/2” bushings from the fox...and it bolted right up. I should have listened to others here regarding pressurized shocks. Lesson learned. I’ll be painting it black.
Lol. That's twice you didn't take my advice. I guess you like spending money and doing things twice... Or 3 times. [emoji23]
Glad the Rancho is working out for you. Just make sure you mount it parallel as possible or it will blow out and you'll be doing it a 4th time.
Hey, your kids are getting tired of doing the same shit over and over. I'm thinking of them. [emoji23]It’s fairly close to parallel... and bite me. [emoji23]
First time in Calico... Ran the Doran/Odessa Loop. Really cool place.
