TrailHunter
I would think not having a dry sump system to be a bigger problem.
Yes.. that was it... it came up a while ago but the thread didn’t get too far.. I may have derailed it.
https://wayalife.com/showthread.php?t=53834
Just buy it. Your mind is made up. Or are you trying to justify your purchase?
Personally I think a catch can is a great idea. You can use all the oil it catches to grease the frame!
I’m not sure about catch cans but that girl on YouTube that was trying to promote them was Hot As F***.
Probably gets pressured into a lot of anal...
“Easy easy, go slow slow” seems to be in every other sentence. Must be her default setting
There weren't oil catch cans on older engines because they weren't "needed". Older engines had the crank vent right on the valve cover or had down draft tubes. Newer direct injection engines are running higher compression and therefore potentially have more blow by. Now instead of crankcases maybe be having a little pressure on them they are under a vacuum now, so now probably more oil is leaving the crank case then would have other wise in the first place.
Really? Pronhub has a lot better content than that. At least you can see some pussy and I’m not talking about her husband.
