JandSJK
So around July I plan on doing some upgrading to the JK. I currently have the 3" Enforcer lift w/2.5 Kings. I also have Currie lower rear arms and Synergy F/R uppers. So what I'm thinking is either doing the High clearance long arm upgrade w/King air bumps front and rear. Or Keeping my current control arm set up and make the switch to coil overs. I haven't decided if I want to do the bolt on or the full conversion and the evo lever rear. I know I want the DTD but not sure the amount and type of wheeling that I normally do warrants DTD and then there is the cost of the DTD. What do you guys think would be the best use of my build budget would be?
