Would there be a way to set this up for a reverse light to be on a three way switch.
Would set the switch to turn the additional lights to come on when the vehicle is in reverse, to be off completely, or to be on independently of reverse lights?
Also, if I've got the A-pillar switch pod, would it be possible to swap this over to be used in conjunction with it?
Great looking setup one way or the other!
Answer is YES.
You would connect the rear flood lights to one of our relay output wires and then connect the 1 to the same power input terminal on the switch in our Trail Rocker panel they want to control the Flood Lights.
The flood lights will still be operational separately and if they want them to be turned on with the backup lights; this would automatically do that as well.
We are actually looking into a-pillar options as well, but the wire length should be sufficient if you wanted to swap our current panel for the a-pillar one.
Does it work on a manual? Any pics of it installed on a manual? (2015 JKU)
We've been working out options for the manual guys and have a '14 manual we are developing on. It will be in our booth at SEMA this year with what we come up with. We're also working on a Trail Rocker setup for the TJ's and CJ's, and YJ is on our list.
We'll provide updates as we make progress in the appropriate sections for each.
Any suggestions from the manual guys on the panel placement is appreciated.
Will the underhood mount interfere with a Genesis dual battery kit?
Judging off of pictures of the Genesis setup, our bracket included with the JK kit will not work. We called Genesis and are going to try to get our hands on one of their dual battery kits so we can develop an optional bracket that will work with it. Beyond the bracket, everything else with our Trail Rocker will work in conjunction with the dual battery kit.
Do we get a forum discount?
Unfortunately, we are not able to offer up a discount at this time. We will, however, be working on a giveaway for you guys here soon.
