cozdude
Guy with a Red 2-Door
I mean, towing is a form of recovery given the circumstanceWhat? It’s not a tow hook it’s a recovery hook. If your towing with that hook you deserve the fail you’ll get.
I know that the kit from WARN requires removing the front skid plate.there are aftermarket d-ring kits that either replace the stock hooks or can be added, they mount to the frame rails.
or modify it to fitI know that the kit from WARN requires removing the front skid plate.
There are good winch plates you can buy that will allow you to keep your skid plate without modifying you Jeep. Take your time and build it the way you want even if you have to spend a little more to get it right.or modify it to fit
Yes. The hook is an open system. The bow shackle is a closed system. Closed systems are safer.If towing using a tow strap, isn't there risk that the strap will fall off the hook?
