MTG
Is there anything needed to keep the motor up besides rotating the mount? Have you had it pop back down after use?
Not sure if you have this or not...
From the EVO instructions:
1. Remove bolt from the front mount of the swaybar motor. (long bolt that goes through the rubber isolator.
2. The motor will now freely rotate on the axis of the swaybar.
3. Rotate the swaybar motor rearward as much as possible.
4. With a ½” diameter drill mark off ½” from tip down on the drill with tape.
5. In the new mounting hole, drill from the passenger side toward the center of the vehicle ½” deep
(up to tape mark) into new mounting hole. DO NOT DRILL MORE THAN ½”. You may need to loosen the two bolts on the passenger side frame rail that holds the swaybar to the frame to get your drill to drill straight into the new mounting hole.
6. Using the same bolt removed earlier install through the factory rubber isolator and into the newly drilled hole.
