And now, last but certainly not least, I'd like to present my last part for the night...
Brake Caliper
Turn signal fluid reservoir. Updated generation 3 by Mopar.
Is it for the rear?
cj7 transfer case switch that was mounted in the glove box.
LOL! You know your old school Jeeps!
This is from a 1979 Jeep Cherokee with the Borg Warner Quadra-Trac Full Time 4WD Transfer Case. They incorporated a vacuum switch in the glove that locked the front and rear output shaft in the T-Case. This T-Case was also used in 1976 - 1979 CJ7's.
Over Drive for an old Willys maybe?
Yup. Worked on a Dana 18 transfer case with both front and rear drive outputs on the passenger side. bolted on the back of the transfer case directly behind the transmission. Since it was a synchro unit, turned your three speed T90 into a 6 speed. Great when you had the stock 4.88 ratio...
