Here is what I am about ready to order. Anyone see anything I may have missed or have opinions on anything? I am ordering the DTD and EVOLever system. I have been going over this a awhile and don't want to miss anything :crazyeyes: Thanks in advance!
Front
Complete Custom Dynatrac Pro Series 60 High-Pinion 8x6.5" Front Axle Assembly - '13 Jeep JK
Custom Machined Dynatrac Pro Rock 60 High Ground Clearance, High Pinion (Reverse-cut) Heavy Duty Nodular Iron Housing w/Pro Rock 60 Nodular Iron Diff Cover
Matched Housing Geometry, Pinion Angle, and Wheel Alignment for Vehicle's Suspension
Axle Width - 68.5"
ARB Air Locker Differential, D60, 35 Spline w/ARB Kit
D60 Ring and Pinion, Reverse-cut 5.38 ratio
Input Yoke, 1350 U-Bolt Style
Heavy Duty 35 Spline/1.5" Diameter Competition 4340 Chromoly Inner/Outer Axle Shafts w/CTM U-Joints
Dynatrac Heavy Duty Dynaloc Manual Locking Hubs
Dynatrac Pro Series 60 Heavy Duty Wheel End Package (Includes HD Forged Steel End Forgings, Nodular Iron Knuckles, Chromoly Spindles, Nodular Iron Wheel Hubs, and Serviceable Timken Bearings
Wheel Bolt Pattern - 8x6.5"
Dynatrac Heavy Duty ProSteer Ball Joints (Uppers & Lowers)
Heavy Duty F-350 Dual Piston Disc Brake Assemblies
ABS/Traction Control Retrofit
Dynatrac Heavy Duty JK high steer arms (1 RH, 1 LH) for Ram assist steering
Dynatrac Heavy Duty 3/16" JK Brackets for EVO DTD
Dynatrac Pro Rock 60 Nodular Iron Powder Coated Differential CoverAxle is Detailed and Painted Dynatrac's Signature Gloss Black
Rear
Complete Custom Dynatrac Pro Series 60 High-Pinion 8x6.5" Full-Float Rear Axle Assembly - '13 Jeep JK
Custom Machined Dynatrac Pro Rock 60 High Ground Clearance, High Pinion (Reverse-cut) Heavy Duty Nodular Iron Housing w/Pro Rock 60 Nod Iron Differential Cover
Matched Housing Geometry and Pinion Angle for Vehicle's Suspension
Dynatrac Dual Sump/High Volume (DSHV) High Pinion Angle Oil Modification
Axle Width - 68.5"
Input Yoke, 1350 U-Bolt Style w/Yoke Kit
Dynatrac Heavy Duty 8x6.5" Full Float Wheel End Package, Includes Chromoly Spindles, Nodular Iron Stub Hubs, Serviceable Bearings, w/13.9" Vented Rotor J8 Military Disc Brake Assemblies
Competition USA Grade 4340 Chromoly Induction Hardened/Heat Treated Full Float 35 Spline/1.5" Diameter Axle Shaft Assemblies (68.5" Width)
Dynatrac Heavy Duty JK EVO Lever Suspension Brackets-
HD 1/2" axle tube
Front
Axle Width - 68.5"
Rear
Axle Width - 68.5"
HD 1/2" axle tube
