Got the front axle cleaned up pretty well today. I'm not tearing it all apart quite yet but will get there haha
Will be cutting off the old perches and setting up the soa perches throughout this week. The weekend is really the only time I have to make real progress unfortunately haha
Don't know how I missed this - very cool! :thumb:
I don't see why not. It would be like putting blocks under your springs.So I'm running into something I'm unsure about. The passenger side perch on the front axle is partially on the dif, im trying to decide how to flip it to leaf over, and don't know how I want to move it to the top. Here's a picture of it so y'all can see what I mean
Could I incorporate the leaf spring perch into a truss?
I'm not seeing the perch you're talking about.
Edit: I see it now. The leafs were under the springs prior and you're wanting to put them on top now.
The tricky part is how you're going to secure your ubolts. That shop I told you about earlier bends and makes ubolts, or at least they did when I worked there. You may have to make one with a larger radius than the other similar to how the OEM ones probably were.
Those spring hangers are riveted on, and they're big rivets and a bitch to get off. If you are careful, you can reuse the hangers, but most of the time they get messed up. Use plasma and an air hammer to cut the rivets.
Good luck on the build. Love seeing an old CJ get built.
