very interesting, will look into this more, the dealer was saying you can't do that cause the hose has it "built in" but we also know how much to trust dealers, this makes a little more sense....Dorman makes them, my fuel line was leaking at the tank, and I replaced it with Dorman.
Also broke a retaining clip and replaced it with Dorman, Like OverlanderJK stated, get a few different sizes, the color matching do not always equate to the same size.
I'm not where I can look at the fuel line hose size, but I believe it's 3/8", you can also remove the connector and using calipers, measure the hose where it connects or the clip opening.
I bought a repair end kit for around $10 and carefully removed the clip to replace the broken clip.
That's fine. The white clip on the inside is what's holding the fuel line on. The blue clip is just a lock like the red part on your abs sensors.Here's pics of the broken clip end.... the good side, and the broken side:
View attachment 391612View attachment 391613
I did have thoughts that it might just be okay as is? just extra cautious with fuel.
that would be amazing news, meaning I can just put it back together and not worry about the back order for the new line!That's fine. The white clip on the inside is what's holding the fuel line on. The blue clip is just a lock like the red part on your abs sensors.
this looks cool as well, thank you - how would one get that made? I like "better than oem" especially seeing as how mopar designs things hahaIf your concerned you might put a piece of tape around it to ensure it stays in place but I wouldn't hesitate to plug it in and run it.
If it bothers you or starts to drip you can always have a line made up out of AN hose and fittings. That would be far and above superior to the stock version and no backorder.
RaceFlux AN Male Flare to Quick-Connect Female Screw-On Adapter Fitting
RaceFlux AN Male Flare to Quick-Connect Female Screw Adapter Fittingwww.anhosefittings.com
Edited to add link
as funny as that sounds, if the ziptie is just holding the blue clip from coming off... that probably would work haha.Put a zip tie around that thing and call it a day.
