Jackboeker83
It definitely wasn't installed correctly by the shop. I think the issue (my Jeep is still being shipped back to NY) I moved the sway bar disconnect into that space to give me more clearance so the shop just put it there. I should have done more research when I saw it but I was assured I wouldn't have any clearance issues. Everything that gave me issues on this trip was the things I didn't install myself. Such a pain.The 2.0, and the 3.6 both have the cooler mounted in front of the frame crossmember/under the radiator. Yours is mounted under the frame crossmember, which will definitely result in your lines being chewed up. Does the 3.0 not allow recommended placement? I've included PSC instructions as well as a picture of my set up so that you can get an idea of where it should go.
