When I was stock (JKUR 4:10's) it always felt geared a bit low for street driving. I tried starting on second occasionally but still preferred 1st. The one thing I'd do on long flat sections of road was go from 4th to 6th. Being on 35's now it feels better on the road being stock geared. I plan on going 37's and thought I'd like 4:88's to bring it back closer to stock but seeing how it's not my DD I'm going 5:13's because I want a bit more off road. As for 2WD vs. 4WD. as previously mentioned its all dependent on what, where, when, and how you're driving. I usually stay in 2WD as long as I can before switching to 4WD. As soon as I have unnecessary wheel spin causing trail damage I switch or if road conditions warrant it. In So-Cal that's almost never..haha. I switch to 4LO when I want to be more controlled on the trail or its requiring a lot of feathering the clutch. When driving in sand or dunes I always stay in 4HI as momentum is your friend. The only time I switch to 4LO in the sand is if I'm stuck and want more control or during a recovery. The RPM's are too high to keep momentum in the dunes in 4LO. I typically use 1-3 in 4HI while playing in the sand (2WD for a little more fun sometimes, doughnuts never get old..). I believe 6th in 4LO is slightly higher than 1st in 4HI (someone correct me if I'm wrong) so that's something to think about also. If your in 6th in 4LO you may want to consider switching to 4HI. Hope this is all clear as mud...haha.
I don't understand why anyone would be getting into 6th gear while in 4LO. The maximum speed in 4LO is 25mph. If you are able to get going that fast what would be the point of staying in 4LO and not going into 4HI or perhaps 2WD if the conditions permit??
Yes that's correct. If I'm going that fast I always shift back to 4HI or 2WD. 6th in 4LO is between 1st and 2nd in HI range. While on the trail it's easier to simply shift into 5th or 6th in between obstacles rather than stop shift back into 4HI to use 1st. If it's going to be a distance them yes I will but if not I stay in 4LO. Also its not recommended to exceed 3K RPM in 4LO.
I haven't heard of 3000 max rpm for 4LO limit. Where did you find this info? The only limit that is stated by the owner's manual (for a 2011 JK) is a 25mph speed limit for 4LO.
Interested in the 3K limit statement also. RPM is based on the engine. If you watch any of the WOL videos i think there are a few instances where the 3k limit is exceeded:thinking:
Not saying you can't exceed 3k it's just the manufacturer's recommendation not to I believe. Think how fast things in the t-case are spinning if your engine is spinning that fast. When I get a min I'll look for it. Hopefully it doesn't turn out to be my grandma's uncle's third cousins sister's ex boyfriend told me that. I'll see where I can dig it up from. If anyone else has info please chime in.
lol, no shit. I exceed 3k on every wheeling trip.
Luckily I am bored enough at work today to download some owner's manuals.
There is no such statement relating to RPM limits while in 4LO in either the 2012 or the 2015 owner's manuals. Just a 25mph speed limit.
So am I understanding this correctly? The sales guy at the dealership specifically told me to not use any gear above 3rd in 4lo, but as long as I'm not traveling above 25mph, any gear is fine? (4th and 5th as well?)
He's a salesman. He has no idea what the hell he is selling you. I've used every gear and fast. Granted you might be wearing parts out faster but it's not going to explode.
