I don't mean to hijack this thread but I have the rigid industries set up and it came with the three style switch (on, off, and on when in reverse). I have a switchpros setup and I was wondering if there was a way to do the same thing through the switch pros? Has anyone done this?
Not directly, but you could rig it a few ways to get a desired result.
reverse/on switch - wire a channel into a relay 85, 86 to ground, 30 to light, 87a to reverse signal, 87 to power. note: this puts a load on the reverse line
reverse/on alternate - wire a channel into a relay 85, add the reverse signal via diode to the same 85, 86 to ground, 30 to light, 87 to power
reverse/off/on needs two channels - one channel straight to the light, next channel, to a relay 87, 85 to reverse, 86 to ground, 30 to light.
Thanks! I'm no electrician so this kind of stuff gets me a little confused... I may just try to find a discrete location for the switch it came with
Sure, the numbers i was referencing point to different pins on the relay. See attached drawing. If you still want to do it through your switchpros, i can spend a few minutes and draw up what you want. Just let me know what features you want
I think having the on/off/reverse would be most fitting for me. I would love to see exactly how you would go about it! Thanks!
