docwilson
I just discovered my rear differential is dripping gear oil. Unbelievably, some of the bolts were literally finger loose. My original suspension install was botched beyond belief and I suspect the same happened here (Dana Spicer covers installed during a re-gear).
I've since torqued them down and will top off the fluid. Is that sufficient if it doesn't leak further? Or should I take the cover off and put a new gasket or RTV? If I replace the gasket/use RTV, do I need new bolts?
Also, the Dana covers have two fill holes, upper and lower. Which do I use?
