onlyone
Got these installed today. Pretty easy. My RC spacers worked great but the factory springs sagged like some granny titties, so I bought some 3.5 springs figuring they will sag a bit with the diesel. Quick update, the factory bumpstop tubes on the diesel seem to be about 1 1/4” taller than the gas so take that into consideration when cutting the stops. I cut around 3 1/2 of the factory metal bumps instead of the 3” they called for. I set is about 1/2” of shock shaft left. Good thing because the tires are pretty close. Lol
Everything worked out fine. The pass side is tight on top with the wiring for the diesel but it moves around fairly easy.
A few pics. I am running Rancho 9000XL shocks for 3.5“ lift. Amazing ride. So soft. I removed the sway bar because I have a Antirock coming.
