JL Stock Tech Specs INDEX
JL WRANGLER SERVICING AND MAINTENANCE
Mileage or time passed (whichever comes first)
20,000 miles or 2 years
- Inspect the CV/Universal joints.
- Inspect front suspension, tie rod ends, and replace if necessary.
- Inspect the front and rear axle fluid.
- Inspect the brake linings, replace as necessary.
- Adjust parking brake on vehicles equipped with four wheel disc brakes.
- Replace air conditioning/cabin air filter.
30,000 miles or 3 years
- Inspect transfer case fluid.
- Replace engine air cleaner filter.
- Replace Spark Plugs – 2.0L Engine**
- Change the manual transmission fluid if using your vehicle for any of the following: trailer towing, snow plowing, heavy loading, taxi, police, delivery service (commercial service), off-road, desert operation or more than 50% of your driving is at sustained high speeds during hot weather, above 90°F (32°C).
40,000 miles or 4 years
- Change front and rear axle fluid if using your vehicle for police, taxi, fleet, off-road or frequent trailer towing.
50,000 miles or 5 years
- No service required.
60,000 miles or 6 years
- Change transfer case fluid if using your vehicle for any of the following: police, taxi, fleet, or frequent trailer towing.
70,000 miles or 7 years
80,000 miles or 8 years
90,000 miles or 9 years
100,000 miles or 10 years
- Replace spark plugs – 3.6L Engine**
- Flush and replace the engine, intercooler (if equipped), battery (if equipped), and Motor Generator Unit (MGU) (if equipped) coolant at 10 years or 150,000 miles (240,000 km) whichever comes first.
- Inspect and replace PCV valve if necessary.
110,000 miles or 11 years
120,000 miles or 12 years
130,000 miles or 13 years
140,000 miles or 14 years
150,000 miles or 15 years
** The spark plug change interval is mileage based only, yearly intervals do not apply.
LUG BOLTS
Wheel Torque Specifications
130 Ft-Lbs (176 N·m)
Lug Bolt Size - M14 x 1.50
Socket Size - 22 mm
Spare Tire Torque Specifications
59 Ft-Lbs (80 N·m)
Socket Size - 22 mm
FLUID CAPACITIES
FUEL
2 Door Models
18.5 Gallons / 70 Liters
4 Door Models
21.5 Gallons / 81 Liters
ENGINE OIL w/FILTER
2.0L Engine
5 Quarts / 4.73 Liters
3.6L Engine
COOLING SYSTEM*
2.0L Engine
(Mopar Antifreeze/Engine Coolant 10 Year/150,000 Mile Formula or equivalent)
9.9 Quarts / 9.4 Liters
2.0L Engine
Intercooler without Motor Generator Unit (MGU) (Mopar Antifreeze/Engine Coolant 10 Year/150,000 Mile Formula or equivalent)
3.2 Quarts / 3.0 Liters
2.0L Engine
Intercooler with Motor Generator Unit (MGU) (Mopar Antifreeze/Engine Coolant 10 Year/150,000 Mile Formula or equivalent)
3.5 Quarts / 3.3 Liters
2.0L Battery
Coolant (Mopar Antifreeze/Engine Coolant 10 Year/150,000 Mile Formula or equivalent)
2.5 Quarts / 2.4 Liters
3.6L Engine
10.7 Quarts / 10.1 Liters
3.6L Motor
1.9 Quarts / 1.8 Liters
3.6L Battery
* Includes coolant recovery bottle filled to MAX level.
FLUIDS AND LUBRICANTS
ENGINE
Engine Coolant We recommend you use Mopar Antifreeze/Coolant 10 Year/150,000 Mile
Formula OAT (Organic Additive Technology) or equivalent meeting the requirements of FCA Material Standard MS.90032.
Intercooler/Motor Generator Unit (if equipped) We recommend you use Mopar Antifreeze/Coolant 10 Year/150,000 Mile Formula OAT (Organic Additive Technology) or equivalent meeting the requirements of FCA Material Standard MS.90032.
Battery Coolant (if equipped) We recommend you use Mopar Antifreeze/Coolant 10 Year/150,000 Mile Formula OAT (Organic Additive Technology) or equivalent meeting the requirements of FCA Material Standard MS.90032.
Engine Oil — 2.0L Engine We recommend you use API Certified SAE 5W-30 Fully Synthetic Engine Oil, meeting the requirements of FCA Material Standard MS-13340 such as Mopar, Pennzoil, and Shell Helix. Refer to your engine oil filler cap for correct SAE grade.
Engine Oil — 3.6L Engine We recommend you use API Certified SAE 0W-20 Engine Oil, meeting the requirements of FCA Material Standard MS-6395 such as Mopar, Pennzoil, and Shell Helix. Refer to your engine oil filler cap for correct SAE grade.
Engine Oil Filter We recommend you use Mopar Engine Oil Filter or equivalent.
Spark Plugs We recommend you use Mopar Spark Plugs.
Fuel Selection — 2.0L Engine 87 Octane Minimum – 91 Octane Recommended, 0-15% Ethanol.
Fuel Selection — 3.6L Engine 87 Octane, 0-15% Ethanol.
CHASSIS
Automatic Transmission – If Equipped Use only Mopar ZF 8&9 Speed ATF Automatic Transmission Fluid or equivalent. Failure to use the correct fluid may affect the function or performance of your transmission.
Manual Transmission – If Equipped We recommend you use Mopar ATF+4 Automatic Transmission Fluid.
Transfer Case We recommend you use Mopar ATF+4 Automatic Transmission Fluid.
186 FBI (Model 30) - Front Axle
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5)
1.82 Pints/0.86 Liters
210 FBI (Model 44) - Front Axle
2.18 Pints/1.03 Liters
200 RBI (Model 44) - Rear Axle
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent.
For trailer towing, use MOPAR Synthetic Gear & Axle Lubricant (SAE 75W-140).
Models equipped with Trac-Lok require an additive.
2.43 Pints/1.15 Liters
220 RBI (Model 44) Rear Axle – EDL
3.06 Pints/1.45 Liters
220 RBI (Model 44) Rear Axle – T/L
3.02 Pints/1.43 Liters
Brake Master Cylinder We recommend you use Mopar DOT 3 Brake Fluid, SAE J1703. If DOT 3, SAE J1703 brake fluid is not available, then DOT 4 is acceptable.
Power Steering Reservoir We recommend you use Mopar Power Steering Fluid +4, Mopar ATF+4 Automatic Transmission Fluid.
The fuses on a Jeep JL Wrangler are located under the hood and in a black box next to the battery. This box is known as the Power Distribution Center and the top cover has a diagram of all the cartridge fuses, mini fuses and relays contained within it.
Because it can some times be hard to read, the following is a complete list of them according to what bank they're in, what they're used for and what type, size and color fuse is needed to replace them.
FUSE BOX QUICK REFERENCE CHART
NOTE: The following information was setup using tables and you will NEED to use a computer or view it from the full site to see it formatted correctly.
LocationDescriptionSizeType
F01Spare
F02Starter40 Amp GreenCartridge
F03IBS5 Amp TanMicro
F04Fuel Pump MTR/FPCM20 Amp YellowMicro
F05Security Gateway5 Amp TanMicro
F06Spare
F07LTR Cool Pump — If Equipped15 Amp BlueMicro
F08TCM-8HP CYGNUS15 Amp BlueMicro
F09Spare
F10KIN/RF HUB/ESCL15 Amp BlueMicro
F11UCI Port (USB & AUX)10 Amp RedMicro
F12HIFI Ampliftier25 Amp ClearMicro
F13Spare
F14Spare
F15IPC/SWITCH BANK-HD ELEC15 Amp BlueMicro
F16Spare
F17Spare
F18AC CLUTCH10 Amp RedMicro
F19Spare
F20CBC 1-INTERIOR LIGHTS30 Amp PinkCartridge
F21REAR WIPER20 Amp YellowMicro
F22ECM/PCM/MGU WAKE UP/PPU WAKE UP10 Amp RedMicro
F23PCM/ECM10 Amp RedMicro
F24Spare
F25MOD_SBW10 Amp RedMicro
F26CBC 2-EXTERIOR LIGHTS #140 Amp GreenCartridge
F27Front Wipers30 Amp PinkCartridge
F28CBC 3-POWER LOCKS40 Amp GreenCartridge
F29CBC 4-EXTERIOR LIGHTS #240 Amp GreenCartridge
F30Spare
F31DIAGNOSTIC PORT10 Amp RedMicro
F32HVAC CTRL MOD/SCL/OCM/DPDM10 Amp RedMicro
F33PTS/IRCM/AIRBAG DISABLE LMPS10 Amp RedMicro
F34ESC/EHPS/SBCM WAKE UP10 Amp RedMicro
F35BRAKE VAC PMP — If Equipped30 Amp PinkCartridge
F36TRLR TOW MOD — If Equipped30 Amp PinkCartridge
F37TRLR TOW CONN 7W — If Equipped30 Amp PinkCartridge
F38ECM20 Amp BlueCartridge
F39Spare
F40DTCM/AXLE LOCK FT_RR15 Amp BlueMicro
F41IC/SGW WAKE UP15 Amp BlueMicro
F42PCR CTRL FEED (ESS)/SPARE (BSG) — If Equipped10 Amp RedMicro
F43PWR OUTLET (CARGO) BATT20 Amp YellowMicro
F44IRCAM HEATERS10 Amp RedMicro
F45PWR OUTLET (CARGO) IGN*20 Amp YellowMicro
F46AUTO HDLP LVL MOD/LVL MTR/HDLP SW10 Amp RedMicro
F47Spare
F48Spare
F49ORC10 Amp RedMicro
F50HD ACC — If Equipped10 Amp RedMicro
F51DSRC/USB/ISRVM/CSGM10 Amp RedMicro
F52CIGAR LTR20 Amp YellowMicro
F53Spare
F54Spare
F55Spare
F56IN-CAR TEMP SENSOR10 Amp RedMicro
F57Frt Drvr Htd Seat20 Amp YellowMicro
F58Frt Pass Htd Seat20 Amp YellowMicro
F59Spare
F60CSWM (HTD STR WHEEL)15 Amp BlueMicro
F61LBSS/RBSS10 Amp RedMicro
F62Spare
F63ORC10 Amp RedMicro
F64Spare
F65Spare
F66HVAC BLOWER MTR FRT40 Amp GreenCartridge
F67Spare
F68Spare
F69MGU (BSG) — If Equipped5 Amp TanMicro
F70INJ/IGN COIL (GAS)/GLO PLUG MOD (DSL)25 Amp ClearMicro
F71Spare
F72HD ELEC ACC PKG — If Equipped10 Amp RedMicro
F73PWR TOP LT20 Amp BlueCartridge
F74PWR TOP RT20 Amp BlueCartridge
F75PPU-BPCM & APM (BSG) — If Equipped10 Amp RedMicro
F76ECM (GAS)/PCM (DSL)20 Amp YellowMicro
F77HTD MIRRORS10 Amp RedMicro
F78COMP/INTRUSION/SIREN/INTRUSION SNSRS10 Amp RedMicro
F79SMART BAR CTRL MOD20 Amp YellowMicro
F80PCM15 Amp BlueMicro
F81REAR DEFROSTER (EBL)30 Amp PinkCartridge
F82FUEL HTR — If Equipped30 Amp PinkCartridge
F83GLOW PLUG — If Equipped60 Amp YellowCartridge
F84UREA HTR CTRL UNIT — If Equipped30 Amp PinkCartridge
F85PM SENSOR — If Equipped10 Amp RedMicro
F86BRAKE VAC PMP 2 — If Equipped30 Amp PinkCartridge
F87SUPPLY/PURGING PMP — If Equipped10 Amp RedMicro
F88NOx SENSOR #1/ #2 — IF Equipped20 Amp BlueCartridge
F89SCCM/CRUISE CTL/DTV10 Amp RedMicro
F90TRLR TOW PARK LMP — If Equipped20 Amp BlueCartridge
F91HORN20 Amp YellowMicro
F92HD ACCY #2 — If Equipped40 Amp GreenCartridge
F93HD ACCY #1 — If Equipped40 Amp GreenCartridge
F94TPM/CORAX10 Amp RedMicro
F95Spare
F96PWR MIRROR SW10 Amp RedMicro
F97RADIO/TBM20 Amp YellowMicro
F98SW BANK-HD ELEC/OFF ROAD10 Amp RedMicro
F99Spare
F100ESC-ECU & VALVES30 Amp PinkCartridge
F101DTCM30 Amp PinkCartridge
F102DUAL USB PORT15 Amp BlueMicro
F103HD ACCY #3 — If Equipped15 Amp BlueMicro
F104PPU COOL PUMP — If Equipped15 Amp BlueMicro
F105ICS/HVAC10 Amp RedMicro
F106ESC-PUMP MTR40 Amp GreenCartridge
F107TRLR TOW STOP/TURN LT — If Equipped20 Amp YellowMicro
F108HD ACCY #4 — If Equipped15 Amp BlueMicro
F109TRLR TOW STOP/TURN RT — If Equipped20 Amp YellowMicro
F110POWER INVERTER30 Amp PinkCartridge
F111TRLR TOW BACKUP — If Equipped20 Amp BlueCartridge
The following are basic specs of both the 2-Door and 4-Door Unlimited Jeep JL Wrangler. This information is also listed out on a new data plate located on the tailgate.
2-Door Jeep JL Wrangler
Wheel Base - 96.8"
Overall Length - 166.6"
4-Door Jeep JL Wrangler Unlimited
Wheel Base - 118.4"
Overall Length - 188.2"
Water Fording Depth
30" at 5 MPH
Track Width - 64.4"
Overall Width - 73.9"
When it comes to building up a Jeep, bigger tires are typically a big part of that equation and the bigger you go, the more concern there is regarding axle strength. Because of this, there have been a lot of questions regarding what axles will be coming on the all new Jeep JL Wrangler and the following is a list of what you can expect to see on a Rubicon, Sahara and Sport. Or at least, this is what I know as of now. :cool:
JL Rubicon - Dana M210 Front / Dana M220 Rear
The flagship JL Wrangler is the Rubicon and to help make it more capable than ever before, it will come with an all new Dana M210 axle up front and a Dana M220 axle in the rear. Unlike any of the other JL models, these axles will measure an impressive 68" wide making them 1.5" wider than a Sport or Sahara and a whole 2.5" wider than what came on the JK Wrangler. I should note that full width axles are typically 68.5".
JL Sahara (Standard) - Dana 186MM Front / Dana M200 Rear
For those of you who want the luxurious options that a JL Wrangler Rubicon offers but don't really need it's impressive rock crawling capabilities, the JL Sahara is a perfect option for you and it comes with a Dana 186MM front axle and a Dana M200 Rear Axle. Unlike the JL Rubicon, these axles measure 66.5" wide which still makes them 1" wider than what came on the JK Wrangler.
JL Sport - Dana M186 Front / Dana M200 Rear
JL Wrangler Sports will now come with a Dana M186 front and Dana M200 rear axle. Just like the JL Sahara, these axles will also measure 66.5" wide.
JL Sahara & Sport Option - Dana M220 Rear
Available as an option, the JL Wrangler Sahara and Sport will also be available with a Dana M220 rear axle which comes as a part of the limited slip differential.
Selec-Trac AWD
While it's not an axle, it should be noted that JL Wranglers that are ordered with the optional Selec-Trac All Wheel Drive system will have front axle shafts that come with CV joints. This is done to help eliminate what some refer to as, "crow hopping" and provide smoother turning.
Again, this information is based on what I know as of today.
For those of you who've been wondering, the following is a list of all the standard features that are available for a Jeep JL Wrangler Rubicon Unlimited - JLJS74.
Code / Description
X9B - 1 Yr. SiriusXM Radio Service
JKV - 115V Auxiliary Power Outlet
JCB - 120 MPH Primary Speedometer
JJJ - 12V Auxiliary Power Outlet
WFK - 17X7.5 Polished Whls w Black Pockets
XEW - 2 Front & 1 Rear Tow Hooks
NF5 - 21.5 Gallon Fuel Tank
BAJ - 220 Amp Alternator
ERC - 3.6L V6 24V VVT Engine Upg I w/ESS
DMF - 4.10 Rear Axle Ratio
DHW - 4:1 Rock-Trac HD Part Time 4WD Sys
NAS - 50 State Emissions
DEM - 6-Speed Manual Transmission
BCZ - 650 Amp Maintenance Free AGM Battery
RFJ - 7.0" Touch Screen Display
RCH - 8 Speakers
BGG - Advanced Brake Assist
CG3 - Advanced Multistage Front Air Bags
HAB - Air Conditioning w/Auto Temp Control
JMA - Air Filtering
LHA - Ambient LED Interior Lighting
BR6 - Anti-Lock 4-Wheel Disc HD Brakes
RFP - Apple CarPlay
RSU - Audio Jack Input for Mobile Devices
LMG - Automatic Headlamps
BC1 - Aux Battery
JJM - Auxiliary 12-Volt Rear Power Outlet
TZG - BF Goodrich Brand Tires
MNA - Black Door Handles
LE4 - Black Exterior Mirrors
MFR - Black Front Frame Overlay
STA - Black Sunrider Soft Top
MF4 - Body Color/Accent Color Grille
XSC - Bright Interior Accents
X71 - Bumper Module I
CKT - Cargo Tie Down Loops
X8S - Center Console Parts Module
CF3 - Child Seat Upper Tether Anchorage
LPS - CHMSL Lamp
JAJ - Cluster 7.0" TFT Color Display
LDB - Console Bin Task Light
LBB - Courtesy Lamps
DJF - Dana M210 Wide Front Axle
DRF - Dana M220 Wide Rear Axle
LMX - Daytime Running Lamp System
GCD - Deep Tint Sunscreen Windows
X82 - Door Parts Module
X8J - Door Trim Panel Module
CDH - Driver Height Adjuster Seat
JJB - Dual Note Electric Horns
RS4 - Dual Remote USB Port - Charge Only
BNS - Electronic Roll Mitigation
BNB - Electronic Stability Control
NHA - Engine Oil Cooler
RDD - Fixed Long Mast Antenna
LNJ - Fog Lamps
X9H - For More Info, Call 800-643-2112
X93 - Frame Parts Module
CLE - Front & Rear Floor Mats
SHG - Front Disconnecting Stabilizer Bar
LCL - Front Dome w/On/Off Switch Lamp
GCB - Front Door Tinted Glass
X83 - Front End Parts Module
X8W - Front Fascias Parts Module
LAX - Front Passenger Seat Belt Alert
CKE - Front Seat Area Carpet
CSM - Front Seat Back Map Pockets
X84 - Front Suspension Parts Module
JWA - Frt Pass Seat - Manual Adjust 4-Way
LMU - Ft Side Marker/Side Repeater Lamp
XEE - Fuel Tank Skid Plate Shield
CUF - Full Length Floor Console
GCF - Full Metal Doors w/Roll-up Windows
TBB - Full Size Spare Tire
RF5 - Google Android Auto
JLP - GPS Antenna Input
X79 - Grille Module
Z1F - GVW Rating - 5800#
LMA - Halogen Headlamps
LHD - Headlamp Off Time Delay
BNG - Hill Start Assist
HGA - Hood Insulation
BPT - Hydraulic Assist Brake Booster
CWP - Illuminated Cupholders
LA6 - Incandescent Taillamps
MBA - Injection Molded Black Front Bumper
MBC - Injection Molded Black Rear Bumper
X81 - Instrument Panel Parts Module
RTF - Integrated Center Stack Radio
XRB - Integrated Voice Command w/Bluetooth
MVC - Jeep Badge
GX4 - Keyless Go
SCV - Leather Wrapped Steering Wheel
JKA - Locking Glove Box
XJC - Locking Lug Nuts
CAC - Low Back Bucket Seats
TXA - LT285/70R17C BSW Off-Road Tires
JRQ - Manual 2-Way Driver Lumbar Adjust
JT6 - Manual 6-Way Driver Seat
WKB - Matching Spare Wheel
RSF - Media Hub (USB, Aux)
MM2 - Molded-In-Color Fender Flares (2-Pc)
APA - Monotone Paint
XJN - MOPAR Black Fuel Filler Door
XJG - Non-Lock Fuel Cap w/o Discriminator
XCA - Occupant Classification System
JFJ - Outside Temperature Gauge
TBR - Outside Tire Carrier
XAC - ParkView Rear Back-up Camera
CSR - Passenger Assist Handles
SDD - Performance Suspension
GTB - Power Heated Mirrors
SBA - Power Steering
*D5 - Prem Cloth Low-Back Bucket Seats
XPF - Protective Coating and Remover
JPY - Pwr Windows, Front 1-Touch Down
XFC - R1234YF A/C Refrigerant
CFN - Rear 60/40 Folding Seat
CSQ - Rear Compartment Assist Handles
CUR - Rear Compartment Storage Tray
LHE - Rear Dome w/On/Off Switch Lamp
CKF - Rear Seat/Wheelhouse/Cargo Carpet
SHF - Rear Stabilizer Bar
X85 - Rear Suspension Parts Module
GNA - Rear View Day/Night Mirror
CDB - Reclining Front Seats
XH6 - Red Tow Hooks
MTB - Red Trail Rated Badge
GXM - Remote Keyless Entry
RSX - Remote USB Port
RS3 - Remote USB Port - Charge Only
MEF - Rock Protection Sill Rails
CGX - RR Head Restraints Outboard Seating
MYA - Rubicon Hood Decal
X8Z - Seat Parts Module
LSA - Security Alarm
GXX - Sentry Key Theft Deterrent System
AEL - Single Top Package
RSD - SiriusXM Satellite Radio
NHM - Speed Control
JPH - Speed Sensitive Power Locks
CLM - Sport Bar
RDZ - Steering Wheel Mounted Audio Ctrls
XHZ - Stop-Start Dual Battery System
CUY - Storage Tray
GNC - Sun Visors w/Illum Vanity Mirrors
CJ1 - Supplemental Frt Seat Side Air Bags
AAN - Technology Group
XJF - Tethered Fuel Filler Cap
CSH - Three Rear Seat Head Restraints
SUD - Tilt/Telescope Steering Column
GBB - Tinted Windshield Glass
X88 - Tire & Wheel Parts Module
XGM - Tire Pressure Monitoring Display
XE4 - Torx Tool Kit
BNM - Traction Control
BNT - Trailer Sway Damping
XEF - Transfer Case Skid Plate Shield
XE9 - Transmission Skid Plate
DSE - Tru-Lok Front & Rear Axles
UAG - Uconnect 4 with 7" Display
XGD - Universal Garage Door Opener
CV3 - Urethane Shift Knob
RF7 - USB Host Flip
JHA - Var Intermittent Windshield Wipers
LAZ - Vehicle Information Center
X72 - Wheel Flare/DRL Parts Module
MG1 - Wrangler Badge
A big thanks goes out to JeepFan for getting this info to me :)
Thank you for this information. Awesome stuff.
But I feel I shoul say something here.
I currently work in the oil and gas distribution industry and we do a lot of training on lilubricants, from PCMOs, to Cuttins fluids and from kerosese to Methanol. Going through all that training, I have learned a few things about lubricants, fuels, coolants, greases, etc.
It's only natural that a car manufacturer would want or recommend you to use their OEM fluids, lubricants, etc. but there are plenty of options, and most are actually better.
As long as the specs match what the manufacturer recommends or the purpose requires, then you can use something else. (Obviously you don't want to use a 10w-30 synthetic blendoil when your car requires a 5w-20 full synthetic.
Besides that, no car manufacturer actually makes their own lubricants or the like.
Example, in the US, if you have a Honda vehicle and you go buy their branded "OEM" Full Synthetic 0w-20 motor oil, it is the same exact thing as Phillips 66 Shield Armor 0w-20 Full Synthetic.​
Coolant, 99.9% of coolant that is marked all makes all models, will actually work in your jeep if you're in a pinch but not permanently unless you drain the old and put in AMAM only. That type of coolant is actually designed to work with dang near all passenger motors, but not all. Any passenger vehicle that requires a silicate coolant, or one that requires special additives, won't take this type.​
Also when looking at coolant, ignore the actual color of it. Look at the specs and know what you vehicle requires. Because different companies will have different colors of the same thing. Most companies try to use a universal color code, but one red coolant isn't the same as another.​
Anyway I'm hopping off this soapbox. I may not know what I'm doing when modding a Jeep, but I am pretty good at knowing the fluids I'm putting un my jeep and other vehicles
